1 - 8 of 8 Posts
We have designed these kits to ensure oil temp is kept at optimum for fast road and track use. Pictured is a 13 row gearbox oil cooler kit for an R34 GTR with an 80 deg. thermostatic switch and relay. 88 deg switch also available as an option. All fittings are high quality aeroquip as is the hose rated to 1800 psi.
There are some variables, you can opt to go for a bigger cooler ie 16 or 19 row, also longer hoses than the 3.5m black braided which is part of the kit depending on where you chose to mount the cooler. Contact us with your requirements.
Fitting instructions supplied.
Prices for 13 row gearbox oil cooler setup with 3.5m hose as pictured.
£399 plus postage.
Differential oil cooler with 13 row cooler and 2m hose
£379 plus postage.
Similar kits using the same pumps and coolers are being used to good affect on several R35 GTR's
Discussion Starter #2
Gearbox, Diff and Transfer box oil cooler kits available. We can also supply to your requirements.
Discussion Starter #4
No pictures of these yet fitted, but we have sold a couple of these kits for the complete car setup.
If you need any information more than happy to talk you through it.
I don't have the luxury of a ramp to play with, so was hoping to see the setups suggested. Will have to keep an eye out of anyone buying and being good enough to share there install :)
Can you just supply the 80 deg. thermostatic switch, relay and wiring please.
Wiring instructions would help as well as electrics is not my strong point.
cheers.
1 - 8 of 8 Posts
