If it will happily handle 500fwhp I would be very interested, is it just the clutch kit or is there a flywheel too. The part no. you gave is just the clutch cover.nc10t . clutch supplied by RB motorsport so if you need something checking i can ask them on monday
Yes it will handle over 500 flywheel horses. Spoke to Richard at RB and he said that the paddle number is ND08TCheers mate, it is 500 flywheel horses I am aiming for. If RB can tell you any info. relating to the maximun power through-put as being 500hp for road car/light track use, I would be very interested in buying.
Ian
Thanks for that, do you have any pics available? Is there a flywheel too?
Ian
Is it hard to set up new map for my GTR?it will start and drive on the base map...but only enough to really move the car about and dont try and drive on boost. Same as a new power fc. Only difference between this and a new one as you dont get a box and instructions with this one![]()
YHPMcould not answer that question as i was going to usa a proffesional engine mapper
Here are some pics. No flywheel includedThanks for that, do you have any pics available? Is there a flywheel too?
Ian
