1 - 10 of 10 Posts
I have for sale new, never used HKS stage II 280 degree RB26 intake and exhaust cams. Lift is 10.2mm
Asking 300GBPs ovno. That's two cams for the price of one. Again, brand new.
HKS says:
Step 2
Offering more power over SS-Cams through increased lift. However, strengthened valve springs (RB26 also require Piston recess modification and Cam clearance on head) are required.
Very good price, abolute bargain...
Discussion Starter #4
mhhforyou, Thanks for adding the info. These are only 10.2mm lift so no valve recess required (unless you shave the block or head). But you will need to shim and clearance the head.
Discussion Starter #7
Really depends on your mods. These cams have made well over 1000hp on highly modified engines, but also work well on lower hp setups wanting higher RPM use.
1 - 10 of 10 Posts
