I have a leak from the attessa system above the rear diff but i cant quite determine where its coming from. Previous forum posts suggest the pressure switch but mine looks more likely to be the accumulator(from the last image). Can the accumulator be removed and refitted
268316
268317
268318
As far as i know, if you take off the accumulator you will need to install a new one as they do not have a re-charging valve.
Easy swap off the car. A very big socket and a lot of extensions on the car. Most of them are busted after 30 years.
When they have lost pressure you will hear the ATTESA relay in the boot clicking every minute or more with the ignition on.
Did mine 2 years back. Big improvement.
So I’m going to replace the accumulator and reinstall.
which oil do I need for refilling?
