car is a 1990 r32 gts4 sedan with all running gear out of 93 r32 gtr.
car was taken off the road for a few months ago for a new clutch respray etc, while that was happening the abs pump was removed and new lines fitted.
now the 4wd seems to be in a default locked on mode. pull fuse and car is rwd replace fuse and it is in full 4wd.
attessa ecu flashes code 8, ABS actuator motor, motor relay or circuit.
any ideas on problem or solutions would be even better.
thanks bryan
thanks bryan
