1 - 20 of 114 Posts
well after 1year and 6 months almost...
my car might finally get to be running so ithought this might be the perfect time to start my build thread here.
i've already started one on GTRCANADA.com. but this one here is just going to be alot of pictures. through out the year.
my car is a 90 bnr32, got it from japan and was suppost to have tomei engine in it, but it wasent what i said to be.
so i decided to dump a bunch of money in it to make it crazy.
when i bought the car
so this is how the car was before, i had the car for 6 days, then it blew up then i toke it apart and found it wasn't a tomei engine, it was a stock r32 engine.....shitty huh.....car cost was 1.7million jp yen in japan.
so here's a list of mods i did
first molding rear defuser
pulling the motor out
open it and found nothing but grex cams
tomei fuel rail
#6 piston ring blew
Discussion Starter #2
swaped the r33 brembos out for my sponsored VTTR Racing brakes
brakes mok up( i know it's upside down )
car being worked on
grex 4 core intercooler
had a few throughts on what to do with the wheels
thx matt for ur photo shoppin help
painted the engine cover hot pink ( but not hot enough )
my cf center console ( i did a new one in yellow cf kevlar )
LED rear plate light
i got a ti exhaust custom fab
relocated the AC unit
arc ti cooling plate
compare greddy intake and oem
custom made cf kevlar exhaust guard
custom made cf lip
shitty cf trunk ( btw: went back with oem after 3 trys of differen't once still no cf trunk is good enough)
relocated battery
arc grill mount oil cooler
rebuild grex 6 speed dog box H patterned tranny
custom made Sard carbon kevlar spoiler made to 1710mm
new spoiler mounts
cf hood
d-speed clear corners
remade brakes lines to fit poportioning valve
Large ic piping made by greddy
apexi evc
greddy oversize pully kit
billion rad hose
family of defis
custom cf N1 bumper ducts
custom cf glove box lid
custom cf side skirt
Nismo engine mounts
Discussion Starter #4
oversized sway bar end link
angel eyes head light conversion
led tail
more hood ideas
cusco sway bar front and back and end links and tension bar
sard 1000cc injectors
over size tranny juice kit
ported head
broken spring off the oem engine
RB30 block
poorly made 4wd adapter
seam welded shock tower
hiding the wires
getting ready to paint the engine bay a special colour
acl bearing kit
ti coated forged pistons
piston with Spool rods
a cool pic i wanted the share
btw: i got the rb30 bottom end build by sydneykid on SAU.
toke him over a year to build when the orig dead line was 3 months and cost was expensive.
i got the motor, it was the biggest POS ever. 4wd adapter doesn't fit sump cuz the holes were off, holes for head studs were drilled slanted, lots of dirt inside engine, piston walls were scratched really badly, and a cracked block.
and i paied $8000aud for that POS.
so just a heads up, if u were to buy anything from him..plz think again.
so i got the block and toke evyerhting apart and had to get it redone. another couple $x000 dumped into the block.
anyways i have more pics to come as i am now getting ready to install everything.
thanks for looking
here is a bump from toronto bro
spent 15min for just looking and saving ur pics~
can't wait to see the final babie
btw love ur fist hood idea~ kinda unique and way better than just leaving it as a whole piece black cf
Wow, Big effort & money spent there, I hope you are winding us up when you kept on putting pink photo shopped wheels on?!
Looking forward to the next photos. :bowdown1:
Superb thread mate. You look to be spending some SERIOUS cash on that beast all in one go! Can't wait to see the finished article :)
Suggestion re. the wheels - the only colour combos I'd say work of those you're looking at are green or orange, although I personally love white rims on a white car :)
Discussion Starter #13
Engine
-RB30DET
-Greddy T78 single turbo
-Greddy intake manifold
-Greddy Exhaust manifold (braced)
-ACL forged pistons (ceramic coated)
-SPOOL forged rods
-balanced / polished crank
-N1 oil pump
-N1 water pump
-Greddy racing BOV
-Greddy 50mm waste gate
-Electric fans
-F-win Rad
-ARC oil cooler (grill mounted)
-Greddy oil cooler (Vmounted)
-Removed ABS, Custom brake lines
-Trust 100mm intercooler
-Areomotive FPR
-HKS 280L fuel pump X2
-Nismo 275L fuel pump
-Sard surge tank + Stainless fittings
-Earles stainless lines
-Grex 272 cams
-SARD 1000CC injectors
-ARC Ti cooling plate
-Trust coolant breather tank
-Custom Ti exhaust
-ACL bearings
-ARP Bolts
-Tomei Type B Head Kit
-Nismo engine mounts
-Greddy catch can
-Custom rad overflow tank
-Racing Battery relocated to behind passenger seat
-Tomei timing belt
-Cometic head gasket
-Alot more to come... !
DriveTrain
-6spd trust dog box H pattern (i couldn't afford the sequential)
-OS Giken triple plate clutch
-Push to Pull type Conversion kit
-Nismo 2 way LSD (custom spec)
-Nismo Engine mounts
Interior
-KTS 7pt Rollcage (custom padding)
-recarpeted rear floors
-Bride Zeta3 (L)bucket (driver)
-AC unit relocated to Glove box
-HKS Boost controller
-Defi Link Water temp. guage
-Defi Link Boost guage
-Defi Link oil Temp guage
-Defi Link oil Press guage
-Defi 80mm Tach 11000rpm (white face)
-Nismo 260km cluster
-Custom carbon center glove box
-Toggles switches
-Power FC Controller
Exterior
-Greddy rear skirts
-Nismo f-bumper
-Custom Carbon bumper Lip
-Custom Carbom N1 side skirts
-Custom Carbon hood lip
-Custom Carbon N1 ducts
-Custom Made Angel Eye N1 headlights
-D-Max Carbon Hood
-Sard GT Spec M Fuji 1700mm wing stands 1210mm (Carbon Kevlar)
-Custom CNC WingStands
-SSR type C 17X9 +21
-Toyo RA1
Brakes / Suspension
-Cusco Tension rods
-Cusco rear camber arms
-KTS front camber arms
-VTTR Front 6pot 2pc rotor racing brakes
-VTTR rear 6pot Racing brakes
-HKS Hyper Max coilovers
-Metal sub frame spacer
-Cusco front & rear sway bar
-Custom over size Endlinks
-KTS lug nuts
Awesomme! But put on the orange blinkers :) Looks like a Primera otherwise (my opinion)
How much did ypu pay for the intake?
1 - 20 of 114 Posts
