Hi,
What sort of things should be checked when looking at R32 GTR's?
How does the insurance compare on these to the R33 GTS-t?
Any info much appreciated,
Vince
Hi,
Forgot where I got these points from, but I printed them off for reference some time ago.
Check for the year of manufacture by looking at the front seatbelts near the floor mounting point.
Inspect the welded seams in the front door sills just below the plastic kickplate. This is where rust has been seen to form, especially on R32's.
Remove the rubber around the boot trim. This is a prime rust spot in any car. While you are there, look in the side panels and make sure they are not full of water.
Feel inside the panels in the boot where the jack is. Debris found in here will tell a story. Watch for glass. (Broken rear window or tail lights at some point)
Inside the engine bay, look for crayon or chalk marks on components. This may indicate they have been replaced with second-hand parts.
Crawl under the car and inspect behind the front and rear bumpers for signs of collusion damage.
Hope these are of some help. :)
-Elliot
Fuel pump failure
Heavily and unevenly worn brake rotors
Oil mist along the side of the rear diff housing due to breather valve blocked by dirt
Oil leak from rear of gearbox due to inner gearbox boot splitting
Leaking sump plugs due to washer failing to seal properly
Damaged/leaking bushes and split ball joints
Damage to sill areas due to forklifts
