1 - 20 of 31 Posts
Trying to modernise the car. I've managed to change my sidelights to some 5 point leds which look great. Now I'm planning to do the whole external bulbs and later on the inside.
Anyway I was hoping someone could help me by making sure I buy the correct parts.
First up led flasher:
Fix Flash Rate Turn Signal Flasher Relay LED indicator bulbs 3 PIN CF14 JL-02 | eBay
This should be good enough? Compatible with the car and a straight swap over?
Indicators:
501/194/T10 Anti Bulb Warning Xenon White Wide Angle 30 Leds x2
and
BA9 1W Wide Angled High Power Led Bulb x2
Rear Indicators:
Tailights:
BA9 1W Wide Angled High Power Led Bulb Bright Red x4
Rear Numberplate:
The Ultimate II 501/T10/194 1 x 1 Watt Ultra Xenon White x2
Reverse Lights:
Have I missed anything? Looking to order these soon so any suggestions welcome.
:thumbsup:
Owner of the MSNSPS
I did mine a while back. Details are in my thread in the Pictures section.
I have a feelng that some of the rear bulbs are BA9S (staggered pins). I should have pctures in my thread of all the bulbs so hopefully that'll give you something to work with.
Yeah you're right, the rear tailights and indicators are BA9S. Dammit that website doesn't list staggered.
Discussion Starter · #8 ·
Update...
So I've finally managed to get all this done. Not to mention the 'R32 gtr bulb guide' thread had listed wrong ones and I wasted money following that thread :rolleyes:
All in all, I've spent around £150 on bulbs just doing this and hopefully I won't ever have to change a bulb again. Tailights were replaced with cree led and so where the indicators front and rear. Reverse, sidelight, reg, and small t10 in indicator all replaced to led. In corresponding colours as well.
Left side normal filament, right cree red led, sidelight:
Brakes on:
Reverse led:
I've done this on my r33 but I have real led tail lights and skipped the indicators. Makes a huge difference.
Also done the interior and clusters. Looks a lot more modern!
Discussion Starter · #13 ·
Yep I agree, I think it should be mandatory to bring the old skylines up to date by upgrading to led interior and exterior.
Do you mind if i would copy you on this? Have been searching for a while for better light options because the light quality isn't good anymore after all these years
I don't think he'll mind at all. It's one of the reasons why he posted the thread to allow others to use the information and upgrade their own lights
Discussion Starter · #16 ·
Yep, as Jags said, if it were up to me I'd make you all spend £150 on led bulbs LOL :bawling:
Owner of the MSNSPS
Brakes on:
Reverse led:
Looks much better. :thumbsup:
Discussion Starter · #20 ·
Yep. Was definitely bay15d for me. I ordered the ba9s (as per the other thread) and it was the wrong size, the bulb was too small to fit in the holder.
1 - 20 of 31 Posts
