1 - 7 of 7 Posts
Just in the process of having my turbo's rebuild and just cleaning everything while it's off the car. Noticed the HKS air filters were brown, I thought they were meant to be green and upon inspection turns out the foam was rotten. Looking around for replacements, I can either buy a replacement foam which is the cheapest and easiest option. There's a £10 hks foam and a £20 foams on the market (ebay).. I assume the cheapest is a fake unless someone has experience
Has anyone had any issues with the hks filters?
Cheers in advance.
Avoid HKS filters, they will let in a lot of dirt. Get yourself something decent like Apexi or ARC airbox. I tend to avoid foam filters because filtration is poor compared to gauze based such as K&N, best still the OE paper filters are the best.
I see that you are new to Skylines and your looking at cheap and cheerful parts to replace ie from Ebay. Remember cheap is not always the best as it will bite you hard in the long run.
If that's the case I will change it to a better quality filter and start looking for something else. I will bare it in mind the cheapness side. Am I wrong but a lot of traders don't have websites?
Just been on nengun and the postage can take upto a month apparently which is good long. Are there any uk suppliers selling an apexi setup?
1 - 7 of 7 Posts
