On Stock R32 Gtrs are the Disc's drilled, if the answer is yes why would a car be fitted with plain ones?
Thanx in advance!
GTROC Co-Founder.
Std disc were drilled yes.
Common to find car with plane discs as they are cheaper and you can use
UK spec 300zx and poss R33, (but they may be bigger I can't remember).
Drilled holes did tend to crack, mine did after 8 years. They never fails though
