1 - 18 of 18 Posts
Subframe with uprated bushes -
4wd pump/solenoid, on cradle etc, with rear ABS sensors -
Front Hubs - with shafts
Front propshaft -
Front control arms - Standard -
Front control arms - Driftworks -
Front Camber arms - Standard -
Front Camber arms - Driftworks -
Rear arms with uprated bushes -
HICAS delete bar -
Wiring looms - What do you need?
Control Units - ATTESSA, HICAS, Inj, Fuel pump etc
ABS Sensors front (both) -
Handbrake cables (both) -
Dash, flocked, 'edited' for cage -
Dials + surround/switches -
i need a tiny bit of loom if you can help, in the boot area, where the loom tails off to the number plate lights etc i need that part of the loom?!?
PM'd you in the past. Still interested in the rear arms. Also the subframe..
And do you have a picture of the dash?
Discussion Starter #12
Some more parts - all prices are plus postage
Driver side door trims - £25
RB26 Cam Cover - £50
Door latch mechanisms (both sides) - £5
(we have locks and ignition with matching key)
Front Drive shaft end - £10
RB26 Standard Cams - £50
Standard Fuel Tank - £20
Expansion Tank - £5
Bonnet Stay - £5
Handbrake cables, mechanisms and shoes - £40
Gear gaitor and surround, and internal boot - £5
Brake master cylinder stopper - £20
Brake master cylinder - £50
ABS Unit - £50
Rear light bulb holders (one clip damaged) - £10
Various intercooler and induction pipes - £10 for all
Clutch master cylinder and lines - £20
Windscreen wiper motor - £20
4WD pump, solenoid and rear ABS sensors - £50
Flocked Dash, edited to fit cage - £50
Power steering pipework and tank - £20
Discussion Starter #14
Dash surround - £20
Dash dials - £40
Front subframe with power steering rack - £75
Rear subframe with uprated bushes - £100
Steering rack with solid bush - £50
Steering wheel boss kit with female section of Lifeline quick release - £30
Plastic 4 Performance full window kit with sliders (drivers side is a bit scrathed) - £100 (for all)
dusty
Hi, am interested in the wiring, especially the one to ecu. But need them to be original and not modified.
Also the dash surround.
Please advise price to Singapore if the wirings are original with all connectors intact.
Thanks.
Discussion Starter #18
Thanks.
Its a 23 year old car.... the wiring will have been altered at somepoint... somewhere. To the best of my knowledge the left hand side loom that goes from the ECU and into the engine bay via a hole near the wiper motor is intact, and has all its original connectors. It was running a Power FC D-Jetro.
Postage complete for both would be £100 from UK to Singapore. PM if acceptable
1 - 18 of 18 Posts
