1 - 13 of 13 Posts
A friend is considering selling his R32 GTR.
Located in Gothenburg Sweden
Mods if its not OK to advertise for a friend - please remove!
Price is £18 000 (210 000 SEK) Please verify exchange rate towards SEK.
R32 GTR TH1 Blue
Mileage is 150 000 km
2000 km after engine rebuild by a Skyline specialist in Sweden.
620 AWHP
Link G4 engine management ( couple of months old)
Engine
Dry sump
TB70 turbo
Cp-pistons and forged rods (there is full documentation from the builder)
Crank trigger
Most parts in the head are from supertech (valves, valveguides, seals, retainers)
Coil overs
Adjustable camber, caster
Sitting on BBS wheels with tripple eights.
electric power steering (vauxhaul corsa)
Fuel cell in the boot
No rear seat.
I think the instrument cluster is missing.
If there is any interest I´ll post a full spec list and pictures.
updated specification
Power 620 AWHP
Engine
Rb26 Dett
Trigger reading on the crank
Dry sump (autoverdi) built in oil pressure regulator
Most of hoses are AN or JIC with pressed hoses
Oil cooler
BMW oil filter housing
HKS cambelt
Tb70 turbo
Bosch 1200 cc injectors
Aiden (swedish manufacturer) Steel manifold
CP pistons Eagle rods witg HD bolts ( rated for 1000 + hk)
diamond polished crankshaft
Balanced engine with clutch and damper
Head was inspected with the engine 2000 km ago.
Valves, guides, seals, retainers are all from supertech
There is extensive documentation from the engine builder with bearing gaps, recommended oil and so on.
Oil service recently done in the entire drivetrain and engine.
Exedy clutch with carbon discs (2 discs)
ARP-bolts for the fly wheel and for the head
Roll cage
Bucket seats
BBS rims with triple eights
No rear seat
Snap off hub for the steering wheel.
Electric power steering from a Vauxhall Corsa
Suspension
Tein Coilovers
Adjustable
Camber
Caster
(Driftworks)
Reinforced arms
Wheel bearing replaced (front right)
A couple of months old link G4+
Will sort out more pictures of the boot, engine bay, interior and underneath.
Yep. But feel free to give a higher offer. :chuckle:
Prices are a lot lower in Sweden unfortunately for us.
Will probably export my own car if I ever decide to sell it.
R32
Niklas
Is the car UK registered?
I might be interested as 3 x R32's (plus my R34) is never enough!
Please can you send me more images and tell me if the car has any rust issues.
Discussion Starter #9
I´ll answer as much as i can. If there is serious interest I´ll send his contact details.
The car is registered in Sweden.
There is aluminum bushes installed in the rear subframe.
If i remember correctly you will need and instrument cluster, centre console and a rear seat in order to make it a bit more original.
Its right now a bit more track oriented.
Discussion Starter #12
Update.
Tuned on E85.
And the rear differential is noisey.
Tyres replaced due too uneven wear.
A buyer should be calculate for a refurb/replacement of it.
1 - 13 of 13 Posts
