hi im trying to remove the front bumper on a r32 gtr does anyone have any advice to where the bolts are etc ive got a boost leak somewhere and im trying to get to the front intercooler pipes and recirc valves to check for leaks
there is a few tricky ones, you will have to take the grill out aswell as the front indicators, as there are 10mm bolts under them,
but its pretty staight forward,
Remove grille and indicators. Remove the following plastic trim fastners (large round washers with a small screw in the middle..
1 under each indicator
3 from underneath grille
1 in each upper air vent in bumper. These are mounted upwards
There are also 2 self-tapping screws just in front of the wheels in the corner of the bumper.
You will also need to remove some of the screws which hold the bumper onto the front undertray. I just cut these out on mine as they were all pretty much corroded. My bumper is now held on by 6 fastners which makes it a doddle to remove (which I seem to do a lot )
A forum community dedicated to Nissan Skyline GTR owners and enthusiasts. Come join the discussion about performance, mods, troubleshooting, body kits, classifieds, maintenance, and more!
