I'm fitting a new filler cap and fuel filler pipe but I have a question on the OE pipe and tank vent.
a) Where is the standard tank vent
b) What is the small pipe that joins in with the filler pipe (is that just to let air out when filling?)
c) Will it all be OK if I block the small pipe and run just 1 2" pipe as a filler.
I have decided to keep the orig fuel tank instead of running a smaller (35l or so ) tank in the boot. Better weight distribution being low down and between the rear axles.
