Finally got all my parts in and took the car to the dyno and the results were less than I expected (although, isn't that always the case
). I was under the assumption that the HKS GT2530s would spool much much faster than they did and I was expecting around 450 whp. Let me know what you guys think..
A/F ratios: started off weak but were spot on after moving around the fuel map and we peaked injector duty at only 74%.
Boost: we went up to 1.4 bar to play it safe on the GT2530s, and when it finally got to full boost, it held steady there moving around +/- .2 bar.
Power Mods:
2 x HKS GT2530 Turbos
2 x 300zx MAFs
Ogura Twin Plate Clutch
Greddy Front Mount Intercooler
Sard 722cc Fuel Injectors
Sard 276lph Fuel Pump
NGK Iridium Racing Spark Plugs
Apexi PowerFC Stand Alone Engine Management
Apexi PowerFC Boost Control Kit
Apexi PowerFC Commander
Greddy dual dump pipe /w decat
Apexi exhaust damper control
5Zigen Exhaust
It was done on a RWD dyno with AWD fuse pulled, no AWD ones around here. Normal pump fuel was used the whole time.
Power Mods:
2 x 300zx MAFs
5Zigen Exhaust
