hello
i have a gtr 32 here in germany...and i am just building the car.
my problem is the following...when i start the car the hicas lamp is on ....but the car has still four wheel drive after 200 meters the 4wd and abs lamps turns on and the car is driving in two wheel drive....
could it be the sterring sensor or the rear diff sensors...i have no idear what it could be...
or can i drive like this because the car is only build for quartermile races...
thanks for your help :lamer:
Skyline Section Manager
Hello.
In the boot, under the parcel shelf, on the left hand side, there is a silver box. This is the ATTESSA computer that controls the ABS and 4WD. There is an LED on the box that flashed. This is a fault code. Can you tell me what the LED does. An example is, it might flash 21 times, pause, flash 13 times, pause, flash 21 times. This is fault code 13 and 21.
Regards
Andy
