I have a r32 gts converted to a gtr. I have the front iprop shaft,axles and and diff in place. If I don't have the full attesa system in place could I still drive it. If not what do I have to drive it
Check out the attesa threads,the best option is a stock attesa ecu,and a maybe a 4wd controller,Skylab's fusion is cheap and works brilliantly as a replacement g sensor.
Hope this helps.
Yes you can drive it but it will only be rwd and you need to plug the hole for the hydraulic line into the center clutch.
