1 - 6 of 6 Posts
My car started to play up last night its started juddering at 4 to 5 rpm the boost it running ok put it on the defies to see the boost stays the same and the oil goes down the 2 psi when juddering its just like 2 or 3 judders from 4 to 5 rmp anyone had a same problem with there car might it be a bad coil, I have no lights come up on the dash if they is a check light iv had a plug out and the top is white and a lot of carbon on the bottom
the afm's are located where your air filter's are,just after your intake,you'll find a box about 1.5" sqaure,with a plug connected to it,and the thing on top of rocker cover would be your ignition amp
1 - 6 of 6 Posts
