1 - 11 of 11 Posts
Is there such a car as an R32 GTR N1? If so how does it differenciate from a standard GTR.
P.S. Does anyone one which spec R32 has 310mm front discs as standard also?
:) :clap:
Yes - they came in white only with Nismo type body additions, no rear wiper, no air con, no radio, undrilled discs and possibly bigger turbos.
Don't know about the discs
Thats interesting, mine has come with no radio, no speakers, no rear wiper, and my discs were Nissan discs undrilled and 310mm on standard calipers, my car also has N1 Turbos, N1 headlights, all Nismo suspension arms front and rear, Nismo Lower ARBars, Nismo vents. The car also has an upgraded crank that Rod pointed out to me when it went in for a cambelt change....he didnt know which one it was either......
Is there anyway to check the chassis no for this?
N1 BNR32 announced 07/19/91
NISMO aero parts
No ABS, air conditioning or audio
Undrilled brake discs
Front brake air guides on tension rods after February 1993
All 326 Crystal White
After 02/92 turbo turbine wheels are metal not ceramic.
Apparently two N1 specifications were available - "ZY" and "ZN" - "ZN" cars have the intercooler mesh, rear wiper and normal projector lights.
I have read that all N1 cars are based on V-Specs (I or II) if produced after V-Spec was launched in February 1993, so all post Febraury 1993 cars should have the 17" BBS wheels and Brembos.
There were only 228 N1 cars.
Phil
Skyline Section Manager
BCNR32 is all BCNR32's
It's the long code after that denotes the actual model variant.
it should be some thinglike
KBNR32RXFS-ZN for the car made 9108-9302
KBNR32RBFS-ZN for the post 9302
The "B" or "X" as 8th letter B=v-spec X=normal
There is also a KNBR32RXFSL-RA which was made 9002-9411?
I can't find an ZL GTR, however there is a ZL KBNR32RGFE, this is a RB20D with an LSD, however in the line above there is ZG, which is a gtr thing
1 - 11 of 11 Posts
