1 - 6 of 6 Posts
Andy Harris from Australia sent photos of his R32 GTR NISMO for posting on here, enjoy!! :thumbsup:
Nice car ... very clean looking ..:clap:
Philip said:
How come it has air conditioning?
Phil
phil. it was fitted with air con on arrival to Aus. the heat here in singleton reaches 40+ degress celcius during summer, so its a little to warm not to have .. :thumbsup:
hope that helps clear that up.
cheers
Specs for my R32
Ok where to start !?
Full HKS spec 11,000rpm engine built by JUN in Japan @ end of 2004.
Full N1 de-burred and polished block
Balanced crank
H-Beam HKS conrods
HKS Forged Pistons
Nismo Hi-volume oil pump
HKS 1.2mm Metal head gasket
HKS Camshafts - 272 degrees
HKS Camgears
Greddy Fuel Rail with 720cc Injectors
Adjustable fuel pressure regulator
Hi-volume fuel pump
2x BB Garrett 600hp Turbos JUN-Spec
HKS piping kit
HKS exhaust manifolds and Balance pipe
HKS dump pipes
HKS intercooler
Aluminium Radiator
Grex Oil Cooler kit
HKS triple plate clutch
Tuned and mapped CPU
Nismo short shift kit
Full HKS gauges - Boost, Oil pressure, Oil/Water temp
HKS EVC boost controller with trigger switch
HKS knock sensor
Factory Nismo body kit and factory BBS wheels
Nismo badging - original from factory
Western Sydney Dragway - 10.8 @ 125mph
18 psi - 460hp at the wheels.
21 psi - 488hp at the wheels.
I hope that covers enough detail for you guys.
Registered user
Nice spec mate,
11000rpm- how is your power/torque curve upon 8000rpm? how safe is it to drive the car like an F1?:bowdown1:
1 - 6 of 6 Posts
