hey guys. after an hour of searching and reading i cant find out which of the 3 power steering pipes, coming out of the reservoir, is for the Hicas and what to do with this line.
any advice is greatly appreciated. thanks :bowdown1:
Skyline Section Manager
There is one low pressure feed from the reservoir to the pump. The rear feed pipe goes to the hicas unit.
hey mate, thanks got the reply. not sure i fully understand tho.
is it one of the 2 smaller pipes that can be removed? if so which one, and what to do with it? thanks
If your ditching the hicas then you just link the two pipes together one on the inner chassis leg on drivers side where the intercooler pipe goes and one you need to cut and flare which runs across the front edge of the subframe just link these together with some 3/8 hose
