Sorry to ask this without doing proper research, but my high pressure power steering line is leaking and I need it fixed fast.
I've got an R33 GTR pump on an R32 GTR
My question is, are the R33 and R32 steering racks similar enough that a R33 high pressure line would work?
The R32 line works just fine(other than leaking) but it is rubbing against my electric fan shroud, I know the R33 banjo connector is a little shorter and would stop this from happening. I would just like to know if they are routed the same and connect to the rack at the same spot with the same connection.
Second question: has any one tried removing this line without taking the engine out?
Jake
