Does anyone have any pictures of a Water Pump(off the car) for a 32GTR. I have a slight water leak and looks like it is coming from the water pump, now when im under the car looking up, my pump has a perfect round hole (this is where the water is leaking) that is in line with the internal shaft, dont know if it should be there so would like to see some pictures to confirm.
Any help as usual would be highly appreciated. Cheers James
hi james
that hole you are talking about is ment to be there and is on most water pumps no matter what model of vehical.
if you have water coming out of the hole it means the seals for the shaft in the pump are stuffed and is time to replace the pump:bawling:
hope this helps
mark
O2 Drift , RHDJapan thankyou for the help with this. Cheers James
