321 - 331 of 331 Posts
You often hear that 'N1' headlights are much lighter than the GT-R's projector headlights.
R32 GT-R 'Projector' headlights are 2.7kgs each including bulbs.
N1/non-projector headlights are 2.2kgs each including brackets and bulbs.
Not a huge saving.
Stu
I haven't had a chance to weigh my GTR yet.
We have removed the following items so far:
ABS Pump
Brake booster
Brake master cylinder
Hicas lines
Attesa pump
Attesa Reservoir
Attesa lines
Rear speakers
Attesa ecu
Any relays and wires from behind the seats and back
OEM Fuel tank and lines
Rear Upper Pillars
Roof liner
Clutch fan
OEM Radiator, Shroud
No Rear seats
OEM Brake setup and lines
A/C
Rear Wiper Motor and wiper
Front Windshield wipers and motor (Rarely drive the car when it rains)
Replaced with:
RIPS Racing AWD Hydraulic system
Bride CF Seats
Cusco Cage
Endless BBK
ABS Delete
Wilwood master cylinder
Custom radiator
So you have removed all the 4WD ATESSA stuff then??
Why?That's what makes a GTR a GTR and not a GTS..
TT
Good point TT. You have just removed the Atessa and replaced it with RIPs setup? Why?
TT
I do not do any circuit racing with the car. I mainly drag the car. I rarely drive my car in the street. A few other cars have done it also before in the past. http://www.speedhunters.com/2014/02/parachutes-panic-stationsa-1300whp-gt-r-street-car/
my setup is complete different than the one above.
Ok so i almost have my engine done and ive been removing everything from the car to leave just the shell, trans, subframes and suspension in place for when it will be moved to the cage installing and painting workshop.
Now im at the stage of removing metal i wont be using to shed weight.
So my question is basically what parts of the shell are structural and i better not touch and which are just metal i can shave off?
