I have a battery draw and have been searching for a wiring diagram with colors? So far I have not been able to find a diagram with colors, does one of those exist?
the battery drain, i have measured current draw in many conditions. I have measured across all fuses in the interior fuse box and the external fuse box and have found no significant draw. I also disconnected the 3 harnesses coming out of the fuse box that is near the battery and the draw is still present. I can measure a significant draw at the fusible link that nearest the engine. This is a thick white/blue wire. After disconnecting many harnesses and still having a significant draw I was hoping to use a wiring diagram with colors to trace the white/blue wire instead of unwrapping the large harness that it goes into at the fuse box.
The car is drivable, just drained after a few days if not driven.
Any help would be great.
