i'm doing an rb25 conversion on my r32 gts. i've read that using the rb25 box, you use the front half of the rb25 prop and the back half of the rb20 prop.
so i took both props to a specialist today and told him i wanted one joined to the other and balnced. then i notice the centre bearings on both are on the worng sides (so if you just unbolted them and bolted them back together you'd end up with no centre bearing.
so does a custom prop have to be made? any help appreciated, cheers
