1 - 10 of 10 Posts
Hi, I have a r32 gts4 and recently I changed my coilpacks to R35 setup but, the cyl 6 is getting too hot and melts.
I use NGK BKR6EIX spark plugs and R35 coils without igniter.
I have an upgraded wastegate that I will replace with a stock one to drive for a while.
Have you adjusted the dwell times for the R35 coil packs? I've read they can get hot without adjustment, but not heard of them melting! :eek: Are they genuine or copies?
I'm not sure you can on a stock ECU? I haven't had mine adjusted yet either, but I'm using an Apexi PFC - I'll have them done when the car is mapped.
Discussion Starter #7 (Edited)
rb20det harnass***12288;for R32 coils with igniter from wiring specialist with wiring pin 1 and 3 reversed.
with bypass of the igniter
First 1-2min will run on all cylinders than cylinder 6 is misfiring.
Discussion Starter #8
Found the problem, harnass issue, shorting out on several places.
1 - 10 of 10 Posts
