1 - 16 of 16 Posts
Hi guys!
After doing this mod and testing it for some weeks in summer, I thought I would write a DIY for all guys who want to do the same.
As it says in the DIY, there ARE several ways of doing it, but I think that my way has more pros than cons.
Have fun!
P.S. not taking any responsibility for any damages ;)
2.95MB Pdf file for download.
https://www.sendspace.com/file/52uqri
Cheers,
RoB
Rob, that's the best I can do, sorry the wiring diagram is upside down.
Hi guys!
Have fun!
Cheers,
RoB
Hi RoB
This is a great DIY. Just one question: What type/size diode are you using?
Discussion Starter #10
I used the 1N5404G diode which is good up to 300V.
Only used this as a whole set of them cost 1.5***8364; (10pcs) and only one would cost 0.30***8364;. It's always good to have some spare for other projects :)
Otherwise I would have used something which has at least 12V rating. :)
Relay 1 control pin 86 should go to LS7 which is low beam not LS6 as indicated and relay 2 pin 86 should go to LS6 - high beam.
Currently working on a design, slightly different from this so will test and post in due course.
Discussion Starter #15
Hi!
As it seems there was a small mistake in the shematics. Thanks to the electrician who found out! Here's the updated version:
https://www.sendspace.com/file/6mdhry
Attached the picture of the correction.
@dj_cruz00: if You're going to write a review, could You please make a new topic to keep this one related only to this topic? Thanks.
BR
RoB
1 - 16 of 16 Posts
