Hi,
Still building my R32 GTST track car and need a few more little bits.
Exhaust brackets - one that connects the cat to the transmission and the second appears to connect in front of the subframe connecting to the chassis.
Large rubber gaiter - The large rubber gaiter that seals the transmission tunnel hole around the gear lever, I have the square metal clamping plate but not the large gaiter.
Radiator lower mounting bushes, I have the top mounting brackets but not the lower bushes.
Radiator - preferably an alloy unit but standard if it is cheap enough just to get the car up and running.
V-band with 3" (76.2mm) outer diameter, struggling as all seem to be 2.5" which is too small outer, or a 3" internal which is obviously then too large(to fit a Holset turbo)
Cylinder head to exhaust manifold gasket (RB20 or RB25)
Rear anti roll bar.
There will no doubt be more things as I continue putting the car together but would if anyone has these bits please let me know.
Edward.
I've got a stock radiator laying at home fro R32 GTR.
It includes the fan shroud and also some hosework.
Perfect to get it up and running, if you PM me your full details i can check the shipping costs for you and see what the total costs will be?
Best regards,
Chris
