I've read the R32 GTR manual and also searched the forums and this is what I've found.
Gear Oil => GL-4 75W90 (approx 4 liters)
Transfer Box => Automatic Transfer Fluid (approx 3 liters)
Front Diff => GL-5 85W90 (approx 2 liters)
Rear Diff => GL-5 80W90 (approx 2 liters)
I have 1 question, the rear diff is described as a mechanical LSD. Is this the reason the R32 GTR dosen't need a limited slip diff oil in the rear? (GL-5LS)
Also what are good makes of oil for the above with the idea to do some track days at some point?
Finally will the R32 need oil coolers?
