Hi guys, im new here. Im having an issue with my cluster where the dials bounce and guages give me incorrect readings. The temperature shoots up, then comes back down/ same for the oil pressure and fuel. I also have an issue where my 4wd light comes on and goes off then works after a start up(not sure if they related) Any help will be appreciated.
267428
I would take the cluster out and check the wiring looms behind for a short circuit. Unlikely to be the cluster at fault as they use a flexible printed circuit which would be much harder to short.
I will give that a try this evening. Thanks mate
