1 - 9 of 9 Posts
What could be the cause of my car running really rich? I changed the spark plugs for new ones (the old ones were very black) and it ran ok on idle for a few minutes but then started missfiring again.
The coils all seem ok no cracks or anything.
I unplugged the LAMDA sensors and it didnt seem to make any difference.
The car did have a SAFC fitted before i bought it - could removing this have screwed something up?
Butuz
Maybe knackered AFM's telling ECU to supply more fuel?????
TT
you can clean AFM's easily by spraying a bit of brake cleaner on the sensor, make sure you let it dry off properly before refitting though.
If you have an aftermarket ecu then id take it to a tuner for a remap (after removing the SAFC it might have changed things ?) and they will find whats causing it very quickly if not...
Ok thanks for that I will try cleaning the AFM's.
I do not think I have an aftermarket ECU but I don't know for sure.
How can I check?
Butuz
1 - 9 of 9 Posts
