Hi there, i thinking about R33 A-LSD rear differential for my project. I build 240 S13 with RB26, have somebody please experience with this differential on RWD car?
Can somebody please tell me, where i can get more info about function this differential? How exactly works? With which parts is connected?
On my car i have R33 RB26DETT engine, R33 RB25 tranny, complete harness from R33 GT-R V spec, with all ECU's ( i hope :) ), R33 rear and front subframe. What exactly i need for swap A-LSD to my car?
How much will it cost approximately??
Thanks for the info, Mirek
Don't put a A-LSD car into your car, you won't have the hydraulic control for it.
Find an LSD out of a non V-Spec R32 GTR or R33 GTR
Some gtst had an a-lsd fitted, if you take the entire setup from one of them it should work.
It's a fun idea but I'd rather have a regular lsd.
Discussion Starter #4
When i take all from GT-R i have this?. I Have already all wiring from R33 GT-R, i need just "harware" (pump, diferential...)
Thanks, but Why? Original is LSD too bad? Why is bad, wokr not correctly? I don't build my car for the race,for street driving, Circuit sometimes is for me better solution GTR A-LSD?
GTST A-LSD have same gear ratio how GTRs?
I don't have problem make some modification, I just need more info, before I do it :) For this car i want it: 1991 Nissan 240SX S13 2.6 benzín 206 kW 392 Nm
How exactly working this A-LSD? Has some ECU? This Ecu need some info for good function. From what senzor? Speed? TPS? Instrument cluster?
I am really sorry for my english :), but thanks for any info
