done a search on the r33 gearbox cause mine is crunching in forth and reverse is getting hard to find and most said get a later box as they are stronger can anyone tell me what year from should i be looking out for. also hows a pull type clutch work compared to push ones
When I installed my PAR Synchromesh Engagement gearset I also install :
Nissan OEM synchronizer parts will be required to fit the gearset into pre-97/12 transmissions
- 3rd gear synchronizer baulk ring ( 1 x 32604-30P61)
- 4th gear synchronizer baulk ring (1 x 32604-40P61)
- Slider(1 x 32611-AA510)
- Hub Assy(1 x 32605-30P11)
- Energizer inserts(3 x 32609-70L15)
- Energizer insert springs (2 x 32603-30P00)
