Although I've has a R34 GTT skyline for the past 10 years I'm a bit new to the GTR . I've just purchased a R33 GTR as a new project and I'm after removing the ABS on it. The thing I'm unsure about is do the sensors for the ABS work anything else other than the braking system. I understand the GTR is not permanent 4 wheel drive and so if it looses traction it triggers the front wheels to drive , ( is that correct?) and if so does it use the abs sensors to tell it to do this or is it a separate system all together. Any info will be much appreciated.
cheers
mike
cheers
mike
