1 - 8 of 8 Posts
After getting all the problems from throttlebodies etc solved and an idle from arround 960rpm I stil question my cas sensor.
What could it be that I need to put the sensor on max turned clockwise to get 20° ignition advance on the engine.
the engine runs good and idle is good but I stil find it weird that I need t omax out the cas sensor for stock setting.
261087
anybody had the same problem ?
Have you removed and refitted the CAS? I've read that unless it goes back on exactly the same it can be out? That's what worries me about mine, I had my covers painted, but I marked my CAS so if it moved I could (hopefully) put it back in roughly the right place!
You cant fit it any other way on the cam I think there is a half mooun on both of them I tried refitting it more tahn 5 times Always the same
Ah ok, yes that makes sense. I remember mine would only go back on one way too. :unsure: Sorry I can't help more!
Sometimes the half moon can be broken/missing from the cam. Belt could be a tooth out too. Pop the covers off and check the timing marks.
Discussion Starter #6
Timing marks are correct checked them
I marked up the cas sensor shaft and tried to put it on turned little clock or counter clockwise and I couldn't .
Half moon is in the cam and in the cas sensor .
really weird
Discussion Starter #7
Think I got the problem the cas alignment pin looks moved . on the pic it looks like the pin isnt straight on the cam gear alignment pin the cam alignment pin is in the middle between the 2 lower cam gear bolts .
So the rotating part of the cas is slightly advanced on the cam so I need to put the cas sensor more counterclockwise to get normal 20° timing .
Is this correct what I'm thinking ?
261109
1 - 8 of 8 Posts
