Hello all, does anyone have any experience with the issue of the clutch engaging at the very top of its travel. I dont know the age of the clutch or if its aftermarket. The clutch disengages immediately when the pedal is pressed, and naturally does not engage until the very top of the travel, which makes the car nearly undrivable. I have tried adjusting the master cylinder rod out, putting the clevis almost all the way at the end of the rod, which did not help. Aside from a bad clutch, are there any other things I should look at before dropping the transmission? Thank you for the help
