1 - 20 of 23 Posts
Crank
Hi
Could you fill me in on the whole story with this crank?
What requires a regrind and by how much in your expert eyes? Have you had this checked by any engineering company/ tuner as yet?
I do know one thing. These cranks can only be regrinded the once.
Can someone shed some light on this please?
I'm genuinely interested in this,
Thank you
Umar
It was perfect until a big end bearing gave way.
The journal has a light score mark on it due to the bearing.
It needs a full regrind in my opinion.
I haven't had it checked by an engineering firm.
I'm assuming its just the rods that spun and not the mains ? How long after it span was it turned off ?
Nothing span, the bearing just ate itself, like there was something in the engine!
I was approching traffic lights, heard a slight knocking shound then all of a sudden alot of knocking and turned it off, rolled to a stop on the side, car was then trailerd home :/
score mark on rod journal 2
I'll take this crank.. Subject to you taking a close up pic of the crank(damaged area)
Like you've taken a close up pic of the Rod/shell..
Discussion Starter · #14 ·
Pics as promised:
The whole crank:
Rod journal #2
Since it's slight damage to one journal you could have this filled and then machined back to the standard bearing size, I believe this is a process that can be done, confirm it with an engineering firm near you first.
Thanks foe the pics.
I'm wanting this, i'll show pics to an engineer and will let you know 100% 2moro for certain.
Regards
Umar
1 - 20 of 23 Posts
