Anyone ever fitted an in tank fuel pump from an r33 gtr to an r32 gtr ?
They are a different fitment, and have a different filter setup. Would pay to get the correct one
Well after a bit of fettling I now have an r33 gtr tomei fuel pump fitted to the 32 . I just cut the rubber casing off and swapped the filter set up using a pick to remove the tiny metal clip that holds it on.
The pumps side by side look identical !
Well done! Goes to show with a bit of work it can be made to fit.:bowdown1:
Thanks ! Shame the r33 Mishimoto rad won't fit !
Could make some top brackets but the bonnet wont shut its taller !
