I have a hard time finding a replacement headlight for my r33 gtr.
can anyone tell me if the GTS model headlight is also compatible with the GTR?
I did a search and knew that the spacer is thicker on the GTR, but other than that can i fit in the GTS headlight on mine?
thanks
your need the top bracket and spacer of your old light, and fit to the gts item :)
i swap one of mine come mot time as its vented
thanks
You have to cut the lower grill mounting tab off the GTS lamp to fit the GTR, then transfer the GTR grill mounting clip and metal spacers over!
make sure you check its a spec 1 and not a spec 2 headlight, spec 2 is a different shape near the grille and wont fit. you need a SPEC 1 headlight
Daz.
