Hi guys, sorry if this has been mentioned elsewhere, but I've Googled and can't find any solid illustrations/answers.
I'd like to know the jacking points on the R33 please. I do not want to use the sills, and can't see anywhere obvious to jack?
Any illustrations would be brilliant if you know of any or can take some pics/show me???
I'm going to be jacking the whole car up (don't have a lift) and plonking it on axle stands for a while whist I change the brakes, and send off the OEM calipers for a refurb and painting red.
I'll send some juicy pics of the build if the brakes work afterwards and I don't die :)
Thank you...
Vince
Ha! Just had another Google and found some "Trolley jack points" :eek:
It's OK! false alarm :chuckle:
I have had mine on axle stands for the last two winters while working on it. I jack the front on the centre of the subframe - it literally has an 'X' on it. I put the axle stands either side of the jack. The rear I jack using the diff, then put the axle stands either side of the diff on the rear subframe.
There's pictures and a description here: How To Properly Jack Up your Car Safely and Support it Using Jack Stands
Cheers.
