due to changing the current set up on my r33 gtr ive decided to sell all the engine components , here are some for now, will list more later.
sard 800cc injectors only 300miles use - £400 plus p+p
nismo break stopper 40 plus p+p
exedy twin plate clutch pull type - £300 plus p+p
2 x z32afm and hks filters - £130 each plus p+p
standard viscous fan £50 plus p+p
4" HKS single turbo twin AFM intake pipe with hoses - £80 plus p+p
cam covers ,coilpack cover and cam gear cover in purple metallic some paint chips - £100 plus p+p
greddy 100mm plenum plus greddy 100mm intake pipe - £400 plus p+p
T51R Kai turbo complete kit inc manifold, external HKS 65mm wastegate and down pipe, oil and water feeds, lambda points on down pipe been welded in but could easily add own if needed - £1500 plus p+p
rb26 head with 262 intake and 272 exhaust hks cams [will split if needed] with hks cam gears, just had head reconditioned - £450 plus p+p
rb26 bottom end with N1 oil and water pump standard crank on standard size shells, needs hone only only 3000miles since rebuild so oil and water pump havent had much use - £500 plus p+p
im a trucker so away most of the week monday to friday so best to call me if you want anything.
my phone number is 07748375748 if you need more details
