1 - 6 of 6 Posts
Hello All,
Think my G-Sensor is playing up.....everything is fine down the motorway until i through it into a roundabout and occasionally the 4WD light comes on and then stays on until ignition off.
Does anyone have one?
1998 UK, R33 GTR V-Spec.
I will confirm part number this weekend!
Ian C,
is the steering angle sensor working correctly? show neutral signal when being driven straight? or the primary/secondary signals from the rear rack assembly not pairing up correctly.
Get the consult on the car and give me a ring if needed.
Mark
Hello mark, was playing with consult the other day and meant to look at the attessa/hicas, but ran out of time as usual.....
i'll have a look and reset if necessary!
Joe, I was in knight racer the other day, you didn't seem to be around! I did see steve's in there for the 400r skirts tho!
i'm over at regent hose again next week, so i'll drop in!
Ian
1 - 6 of 6 Posts
