1 - 15 of 15 Posts
Hi all just wondering i have above car (brembo brakes)and the brake pedal is very hard there is servo action because if pump till pedal hard then start engine with foot on pedal the pedal does move slightly. But the brakes don't feel very good alot of pressure needed but not a lot of stopping power. is this normal.
No - doesn't sound right - check for vacuum leaks on the pipes from the manifold to the brake servo and the clutch servo - clutch servo sometimes splits on the end of the can.
As above - what pads are you running? Some higher temp pads require considerable heat before giving a better feel. Lower temps or coldness on mine for example gives a kind of wooden feel until I have got some heat into the pads and discs at which point they become much better and responsive.
Hi thanks for ideas will check all hoses. Pads look normal but will remove on weekend to see if non standard are fitted. what is the round plastic black canister in between vacum pick up pipe to servo pipe sits o/s/f under bonnet what is and what does. Thank you.
Did you manage to get to the bottom of this? Think I've got the same issue, some servo assistance but when pressing pedal hard, it takes a lot of force for not a lot of stopping power, just changed to ebc discs and ds2500 pads
been thinking the same freakazoid...whats the best way to track a leak down as some of the vac pipes disappear beneath the mani and dont wanna strip all that out if its something else!
1 - 15 of 15 Posts
