1 - 8 of 8 Posts
Hi all will a rear v ssec r33 gtr diff fit the r32 gtr or are there problems any help appreciated cheers.
You will need the drive shafts aswell.
Then you'll need the pump assembly and all of the electronics which I believe includes the attessa ecu.
It's alot of work and not worth it.
What's different in the 32 -V-Spec- diff ? I thought that is the same R200 than in the normal version ?
Discussion Starter #6
diff
Ineed to replace or sort my diff mines been shimmed really tight allmost locked and makes some scary cracking noises when pulling out of junctions sounds like a classic scooby ra with diff lock engaged.
there is a lot of work plus the rear wireloom will not plug up unless its a vspec wireloom for vspec pump unit and vspec lsd
1 - 8 of 8 Posts
