Supension and 4wd
Front Brembo brakes £360
Front Subframe £60
Steering rack minus track rod arms £40
Front passanger side lower wishbone £20
4wd pump and pipe work £100
4wd resisvior and pipes from boot £30
Body work and exterior
Passanger side door£50
Door handle £30
Passanger side door glass £50
Door card £20
Window switch £10
Window motor and mech £20
Rear bumper bar with number plate lights £10
Rear bumper £40
Intercooler mesh for front bumper £10
Scuttle panel £20
Bonnet hinges £20
Boot hinges with dampers £20
Front arch liners ( rear sections only ) £10
Rear lights complelt £80
Front bumper indicator surrounds £20
Bonnet catch and cable £20
Full lock set with orginal GTR key bar the boot lock £80
Front section of side skirts £20 for both slight clip damage
Electrical
1 X Afm standard. £30
Start motor and wiring loom £50
Coil pack loom. £30
Hicas ecu £10
Little ignition barrel light. WORKING £10
Front wiper motor £20
Windscreen washer tank with both pumps £20
Wiper stalk and light stalk switchs £20
Hazard and rear heater screen switchs £10
Electric ariel. £5
Sub gauges from center consul. £30
Boost gauge sensor £5
Climate control sensor from center consul £5
Front wiper motor relay £5
Boot fuse box and relays £20
Battery earth £5
Horns £5
Stanard boost soloniod £5
Battery clamp £10
Full car wiring loom including relays and fuse boxes £100 Can cut sections out if you need plugs or just seperate relays
Dash clocks/ speedo cluster. Lugs have snapped off both all guages still work it anyone needs any. £40
Full a/c system. Rad/condensor, pump, fan, pipe work. Will split £offers
A/C climate controller ( bit that sits in the dash) £40
Interior
Metal fuel pump cover for boot £5
Upper gear stick rubber gaitor and plate £5
Rear speaker covers £10
Air bag £20
Steering wheel £20
Dash vents. Top ones that blow onto the screen £10
Rear parcel shelf vents £5
Engine compartment
Header tank £10
Carbon canistor and bracket £10
Any offers will be considered
Front Subframe £60
Door handle £30
Door card £20
Window switch £10
Rear bumper £40
Scuttle panel £20
Bonnet hinges £20
Electrical
Coil pack loom. £30
Hicas ecu £10
Electric ariel. £5
Battery earth £5
Horns £5
Battery clamp £10
Interior
Air bag £20
Steering wheel £20
Engine compartment
Header tank £10
