I failed a warrant of fitness today for my R33 GTR with the front window washers not working.
On inspection I found that there are two motors in the window washer bottle, one for the front washers and one for the rear window.
The rear one still works fine but after checking the connection to the front washer motor, there is no power to that plug. I have checked the fuses but there appears to be no separate fuse for the washers.
Does the washers share a fuse with something else? The wipers still work fine.
Is it most likely the switch on the washer stalk?
Anyone here electrically mined who might have an idea on this problem?
