Hi as above the car started cutting out when laboring the engine at 0bar of boost as soon as you go above that it cuts out, i have looked at all turbo hoses and vacume pipes and everything seem as it should be.
It had a bit of a missfire in the top end of the rev range and would occasionaly missfire when just driving at a constant speed eg 60mph.
Now it just turns over and wont even attempt to start.
Could it just be a coil pack has given up!? I would have thought it would still fire up unless it is the junction box they all feed into (for got the correct name for it!)
