hi guys, I currently have 280mm r33 skyline gts brakes on my car (a silvia)
I'm looking to upgrade to the r33 gtr brembo calipers with the 324mm discs
however I am led to believe it's not just the diameter of the disc that changes? I've been told there is a difference in disc offset apparently?
can someone please confirm this and explain what the differences are? weather the caliper will sit closer to the inside of my wheel etc?
thanks
jonny.
They are a direct bolt on but the caliper will be closer to the wheel by approx 25mm. this is if you have the 33 gts twin piston sliding calipers on at the mo.
Ive fitted a set of 32gtr non brembos to a s14 na i have with no probs apart from needing wheel spacers.
