HELP.............
I fitted a second hand auto 'box to my car last night because the old one had started to slip a little.
I changed the fluid and that made it slip like hell in drive, although 1st and 2nd are fine.
I have read up about auto 'boxes and decided however to fit this replacement, it is exactly the same as the original one a lot of hassle for nothing....
I suspect the clutch packs are worn in both, however the std ATF did make things worse, so as a stop-gap can someone recomend a 'grippier' ATF, or even what should it have in it?
Andy.
Andy.
